oil leak
Car  RenaultSport clio 172 mk2
Has anyone else come across their rocker cover leaking on their mk2 172? Mines leaking, not much but I think its getting worse. I went into my local Renault garage and they said its a job what takes 7.3 hours! Has anyone done one themselves? Does it really take this long because at about 70 quid an hour labour its a lot of dosh just for a rocker cover!
yes its fairly common
speak to GDI in cambridge
or Rentech in portsmouth (i think)
its not a DIY job
i would say about 50% of clios have this problem....
if you fancy tuning work, then this is the time to get cams fitted as its the same job as changing the cams
Andy
How can you tell if its starting to leak, does the engine cover need to come off? Sort of thing thats worth checking before warranty finishes!
most leak a little oil, take your plastic cover off and check your bolts. Numerous threads on here with photos etc.
Mine has leaked a little from a couple fo the bolts for about a year now. Leaving it tho.
Cheers for info Liam. Did you nip the bolts up , or does it leak even if they're tight anyway?
havnt tried, dont think you can get to the bolts, not unless you have a bendy spanner type thing..
you can't just "nip them up" as andy says, the rocker cover is the cam bearings/cap built into one
they all have to be tourqed correctly
you can remove the suspect bolt, silicone (thixo??) the hole and wack the bolt back in and tourqe correctly, this is the renault bodge
they have very light torque on the bolts 120 dNm, over about 30 bolts...
freds comments are worth a try.... its worth a go...
Andy
