Oil,oil filter and fuel filter change!.
Car  Renaultsport clio 172 cup
Servicing the car and bought all of the above today first of all will 5l of oil be enough and where do i locate the fuel filter,also what tool do i need to remove sump plug thanks.
you don't change the fuel filter, its inside the tank, part of the sender unit @ £300+ and has a service life of 150K miles
8mm square for the sump
8mm square socket for the sump plugs.
fuel filter, i'l let someone else take that. good f**king luck though!
Thanks boys oh well can bin the fuel filter then lol,will the 5 litres be enough then?
my ph1 has a fuel filter underneath the car :D only cost me £3.50
should be 5.1 l to fill it
just try it you might be ok
Got 5l of elf evolution sxr also got some other fully synthetic oil should be good to top it up with that if theres not enough elf?.
Yeah, its only mk2ph1 clios that have them easily serviceable under the car.
5L will be enough, the book says 5.1 but ive never managed that without going over the max line. You may need some spare for topping up though after a while depending on your engine.
