Oil Pressue Light only above idle
Car  Clio
Hi
My Clio 182 will put the oil pressure and stop warning lights on if the engine raises above around 1,000 rpm.
I am hoping it is a sensor fault but if it were wouldn't the light be on all the time?
Thanks,
Sensor should only trigger on low oil pressure so would not expect it to trigger when revved as oil pressure should increase ? I would replace it and go from there. If worried hook up an oil pressure gauge and see whats going on.
Hi
Yes that's what I would expect, so would ha e thought it would come on at idle as well. However it only comes on if the engine goes above 1000 rpm and then it will stay on.
I will replace the sensor and report back. Are there any recommended brands or is this one of those parts to only get from a Renault dealer / Ktec etc?
Thanks,
Hi
Looking at stockists of the oil pressure switch, is it right that I need the 0.5 bar rated sensor?
Is Facet an OEM spec part as well to save going to a Renault dealer?
Hi
I resorted getting a genuine 172 / 182 oil pressure switch from RPD. I have installed it however before doing so I compared it to the one which came off the car.
Why does the old switch have a bigger diameter hole in it?
