oil pressure sensor
Car  PH1 Track Car
after having the light flash on and off for a day, then not coming on for a week or so, it has now started flashing again
i have decided to first change the oil pressure sensor as after some research this seems to be the most likely cause
only question is, the place my cousin works at (eurocarparts) sell two different sensors, one that says 0.2bar and one that says 0.5bar, which are £6 and £14 respectively
which one do i need?
any input would be greatly appreciated as i want to sort the problem asap!
thanks
ash
try taking the old one off, maybe theres a serial number on it? i swapped mine some time back, didn't even know theres two!
