OIL question for 182
Car  renault clio 182 cup
Im thinking of changing the oil on my 182 as it has done nearly 6000 miles,what oil would you recommend,how much oil do i need and would i need a new sump plug washer,if so can they be brought from halfords etc. many thanks in advance.
Pro silkline 5-40 is a popular choice.
Ype you need a new sump washer otherwsie it will leak out. £1.10 from Renault or about the same probably at Halfords but I think you get a new sump nut as well (not that you need one though).
sump washers for the Mk1's are only 10p at the dealers.......
do the Mk2 not use the same type ?
Nope Mk2 owners are rich so they have to pay extra for a special washer.
The Mk1 washer would fit but if Renault say don't use it I'm not going to risk it.
The Mk2 washer is a bit bigger and wider and has a bit of rubber round the outside.
