Old D-Link Router whats its IP?!
Car  Pink & Blue 182, JDM DC2
Have dug an old D-Link 504 ADSL Router out of the cupboard at work but have no ide what its IP address is.
Anyone got any suggestions as a possible way to find out?
Best way would be to do a factory reset it and then connect something to it and use DHCP, then check ipconfig/all to see what the gateway is and bingo..
My IP at the moment on my lan (192.168...) might be different to that of the machine (10.0...) should it still find it?
Hmmmm i know its been used for offsite stuff internally so I know its quite likely to be on a 10.something range.. :(
well if youve got a 192.168 address, itll have dchp'd you
so just look at your gateway - control panel > network connections > lan > support
Its not the router i'm using and we don't use DHCP.. already tried that ;)
your router will have an internal lan ip of 192.168.*.* the external wan ip may be of the form 10.*.*.* or whateva
how have you connected it to your machine?
Wanderer - theres nothing that indicates that the internal lan range will be 192 based. It has a 4 port hub built-in of which i am cat5'd into.
I'm also connected through serial to it where it keeps saying "Retrain the line"
Dude i'm not even that close... i can't even log on to it... if i could, i'd know its IP ;) I've just got lots of this..
Retrain the line
Retrain the line
Retrain the line
Retrain the line
Retrain the line
Retrain the line
Retrain the line
Retrain the line
Retrain the line
_
thats it..
my dlink stuff is all 192.168.1.1 or 192.168.0.1 if u ahve changed it and there is no reset button dunno what yu could do.
DarthCake said:
Thanks Daz. Sadly not an option. NEXT!
Disco - that was really helpful. cheers.
Hmm, Hammer?
Seriously.. plug it into an ADSL line.. see if it trains.. heh.
Play an online game halo for example, your IP address will come up in the multiplayer screen..... ;)
well at a guess, 'retrain the line' seems to imply that the connection to the router over the serial port is not at an adaqate speed setting. So if you increase the speed range of your com port, it may allow the router to select a more appropriate connection speed.
either that or the cable is buggered
the_wanderer said:
well at a guess, 'retrain the line' seems to imply that the connection over the serial port is not at an adaqute speed setting
Ah, could be..
I read it as the ADSL connection as that's trained..
9600 is the baud rate for Cisco stuff..
Where do I start with this one!!
Firstly, I recommend buying a new keyboard!
Ok guys all very helpful but its kind of mission critical we work out how to get onto this router. Its isolated and attached to another pc so I need some kind of scanner to locate it.
I can't replace it with a Cisco as 1) its not my money and 2) its not my router.
Now if we could get back to the task in hand. Thanks
I've got that running mate. As per my original reply..
If my laptops IP was 10.0.1.1 and the routers IP is 68.43.90.189 would it still eventually find it after scanning all the ranges??
The only plus thing is I'm pretty sure its on the same subnet
