old prime lenses
So I've been having a gander at old primes for my D3100, I can't afford a newer prime at the moment due to the car needing a cambelt and brakes.
Now I know there won't be any autofocus and I'd need to adjust aperture manually so that's not a problem.
Basically I'd like to know if it's going to be worth the 30-40 quid for one.
Regarding use, I do a bit of everything except portraits, Night photography being my favourite, along with small projects like water droplets and the typical car shots.
I still have some sigma len's (not DX) and used to use them, but tbh the lack of autofocus started to become a pain so I just got some new dx format lenses and having ouch the others since. you might find the same.
I don't use the camera regularly though, and I've got a couple old lenses that obviously aren't able to autofocus and it doesn't really bother me. I was thinking more along the lines of Image quality.
Also, apparently (so I've read) the bokeh isn't all that on older primes, is this true?
I cant comment on that. keep in mind the crop ratio when buying older lenses though as that is sometimes overlooked (i.e. a 100mm non-dx lens wont be 100mm on your camera).
I've got an old Vivitar 28mm f2.8 that I use now and again.
Think I only paid around 20 for it and probably 20 for the Canon fitment adapter.
Should start using it more as it's a fairy good lens. Will also look at some other Vivitar ones too I think maybe some wider ones if I can get them cheap.
I've got a fujifilm f2.8 macro lens that I got from a car boot sale, for a fiver! It's quite a nice lens to use, bit beaten up externally but it functions perfectly. There's a guy who sells on ebay only a few streets away too but he rarely has anything worth buying which is a shame.
