Omex 600 help
Hi if anyone can help ASAP I would appreciate it. It's not on a Clio but it shouldn't make a difference here.
brief summary, omex is
Reading map,
reading tps,
reading engine speed of roughly 210 rom,
reading a timing error (missing tooth)
running fuel pump whilst cranking.
i can't get injection or spark. The coil has a feed when cranking and the injectors have 12v on both sides of the plug when it's not connected to an injector (this isn't right?)
can anybody advise?
What as it ? Just seen your post and it sounds similar to the problem I had , unfortunatley mine turned out to be a damaged ecu which required a new processor board.
Too many teeth on the flywheel.
car still won't start ATM but I have a fuel pressure problem now I think.
pump is being a bit of a pain
