Omex and cts
After some help from someone who has used the 600 before?
basically the idea I've had is to run my coolant gauge with the omex using a PWM aux out on the omex, problem 1 is there's no pin in the plug to give me an aux out cable. Can I simply get a pin from a location I'm not using and put it here instead of the blank space to give me an aux out?
problem 2 is the coolant gauge was run by the standard ecu using a 3 pin cts to the ecu then from the ecu to the gauge via 2 wires. Am I right in thinking that one of these wires will be a coolant temp warning light and the other a feed for the gauge? (This isn't on a Clio btw, this is what I've learnt through f**king about and looking at Renault diagrams)
so can it be done?
