Omex water temp sensor
When fitting an omex ecu do both your standard & omex ecu need a water temp sensor? If the do do you just drill & tap the m12x1.5 hole into the housing or do I need to weld a boss on first?
Adey.
There's a spot to drill it into so both the dash and the ecu still get a signal. Best to call them as thy used to have a picture available of where it went
