Omg Look At This!!
Ive decided now that im getting the Alpine CDA-9855R headunit this xmas but i thought i might as well get my amp and subs while im at it.
Im thinking of getting two Alpine SWR-12's but i dont know what amp to get because i get confused with all the jargon lol
could somone please choose me an amp, and if you have any other suggestions of subs ported, sealed or just think that two alpine r12's is a stupid thing to do then say because its all bloody confusing. lol
cheers, shaun
You need something that will run two subs at just short of full power. example, 2x 600w subs, get a 1000w amp.. that way, your less likely to blow the amp and subs apart. As for choosing the right amp, I couldnt tell you that one. Someone else might be able to recommend a decent amp.. They all vary.
As for your thread title, bit deceiving! :nono: pmsl
Shaun,
I own my own car audio centre in Lowestoft, and also supply the Type R owners club / forum with all their ICE equip, so i can advise the correct equip for you and you needs as i have alot of knowledge and experience.
There is a big selection out there and amongst them is some cracking gear but also some shockingly bad stuff.
Firstly what sort of music do you listen to????
Secondly what is your rough budget you have to work with???
Lastly, buy stateing you want 2x 12" subs i assume you like bass. Is it high output you want or SQ?????
steve
high bass and good quality if thats possible lol i already have some good old 13cm speakers in both front and back doors but want more bass. i listen to DNB, trance, RNB, hip hop, gangster rap the lot so i want fast bass for dnb and trance but deep tuneful bass for the other stuff. Im working to a budget of around 300 maby pushing 400 for the subs and amp and getting it fitted because i havent really got the knowlege to do it myself.
ps. sorry about the name, at least it worked lol
Shaun
Right
First what do you want ?
Do you want a high quality system or one that booms and will sound loud outside that car?
Next do you want flash or subtle?
Thirdly £££££ How much?
Give me an answer and I wil spec you a system
oops just read one of your responses!
£400 quid more quality than boom look at my 20 inch woofer that sounds crap I take it?
http://www.talkaudio.co.uk/exchange/showproduct.php?product=4457&sort=1&cat=4&page=2
Great Digital AMP will run 2/3 subs
http://www.talkaudio.co.uk/exchange/showproduct.php?product=4497&sort=1&cat=6&page=1
two very nice subs for £180
That leaves £50 for MDF etc to make a box or £50 to pay someone to make one for you
THis does not include RCAs or Speaker Wire ot Power Wire though, you will need at least 8 guage for that amp
wrong;)
2x 600w subs = 1400w amp ideally
and steer well clear of audio barn as they are b****cks
yeh thats why i was looking at alpine as i know they are good. but put it this way ill spend £400 tops on subs and amp and fitting ive had one bloke in an ICE shop local to me quote 300 for subs, amp, wiring, and he will fit it all for 300 but he was tryin to fob off some shitty looking and sounding make of sub which id never even heard of so i said i would think about it. these subs have got to be able to take some punishment lol
Dink said:
wrong;)
maybe so dink .. but I'm a believer in not tempting fate and wanting a fire in the back :D
well a clipped signal is ten million times worse than a slight bit of clean overpowering
So your budget is £400 and you want 2 x Alpine Type R's...
Let's work with the amp first. As the Type R's are 300w RMS, and have different voice coil configurations, there'll should be loads of amps you can choose from.
The type r's come in dual 2 ohm and dual 4ohm, so if you have 2 of them, you'll need an amp that does at least 600w RMS @ 1ohm (for the dual 4's) or 600w RMS @ 2ohms (for the dual 2's).
Something like this would be ok..
http://caraudiosecurity.com/shop/product/products_id/3567.html
1000w RMS @ 1ohm (14.4v)... If you have the 2 x dual 4's, wired in paralell, this amp would give each sub 500w RMS... overpowering subs isn't a problem as long as your careful with the gain control! NEVER underpower a sub!
As for the subs, you'll want the dual 4ohm version if you were to get this amp..
http://caraudiosecurity.com/shop/product/products_id/533.html
w/ box http://caraudiosecurity.com/shop/product/products_id/1191.html
That keeps you with extra wiring for wires etc etc.
As you've said you like various types of music, i'd suggest a sealed box as a ported box needs to be custom designed to the sub and will take time and money...
You could go for one decent sub/amp but that's to be left for another post :)
Yeah most likely.. ported boxes are also usually much bigger than sealed boxes so you'll have no space for 'shopping'..
Example of 1 decent sub within reasonable budget?..
http://www.caraudiodirect.co.uk/pro...d=2962&cadid=0ab89f0c5d9ca1be900c25eb05e1e9b7
The R.E SE, good sound quality and will go stupidly loud in the right box with the right amp... Don't let the RMS figure fool you though, you may think it takes 'only' 600w RMS, but it'll handle shitloads more!
Well if you want to save boot space, go for a sealed box, it will still sound good...
If you go the ported route, you'll need a custom made box and it WILL fill up the whole boot
i got my system on a budget, I found buying second hand from ebay saved me a lot of money and got me better equipment for a similar amount as a budget system new. Just a thought.... BTW it all looks new anyway. I just took my time and got a bit each month when a bargain came up on ebay.
