OMP discs, any experiance?
Car  Clio 1.2 16V Dynamique 02
Hi there,
I was thinking about upgrading my brakes for the next service/ point in which I do something to the car. I don't do track, I only use the car on the road.
Have any of you guys heard about or used OMP discs? What pads would work well with them? DS2500s? Greenstuffs? Is it necessary to upgrade the brake hoses to steel braided ones? And is DOT 4.1 fluid fine for what I need?
Sam
My two pence.
You have a 1.2 so braking isn't as major a concern as the bigger engined clios.
Get: Decent pads (not greenstuffs, maybe these http://www.k-tecracing.com/show_product.asp?id=2688, you don't need DS2500 for road use), good standard disks or decent aftermarkets ones like omps, braided lines and a complete refill of the brake system with good quality branded dot 4.
You don't need anything else for road use.
J.
I have to agree with you the fact it is a pretty small engine so I'm not going anywhere too fast!
So would this sort of set up reduce the spongy-ness? When getting new discs and brake pads is it always best to get the braided lines because thats another £55? Is there any set up that would be within £120? Or could I just leave the original discs on?
Thanks for the help
Sam
