OMP Roll Cage bolts
I have a 6 point OMP roll cage that i know a load of people on here have. I need the bolts as the guy i bought it of said they had rusted. What bolts are needed (size etc)? It has the door bars and it bolts together with the two sleeve's etc.
Which bolts? The ones that go to the base plates, or the ones that attach the front to the back, or the ones that hold the door bars in?
Have you got the base plates that you have to weld in?
If you haven't got any it might be best to ring OMP and order a fitting kit for it
The ones that hold the door bars and also attach the front to back. Apprantley the base plates that omp provide are rubbish. The welder that is going to fit it will make some up for me.
Yeah I used the plates that OMP provide for the rear - but reinforced them, front we ended up making some but they're quite complicated
I'll measure the bolts in mine at the weekend if you want?
To be honest though as long as they're long enough to reach and use hex heads so there's nothing sharp for you to whack your head on you can't go wrong
The bolts to hold the cage down and fix front to back are M8. Door bars are bigger M10 or M12. Get at least 8.8 high tensile steel.
There's nothing special about them really. No bolts in the fitting kit.
