One dud xenon, help please!
Car  182 FF
First post so be helpful please!
I've had my 182 for only a couple of weeks now and my o/s headlight has stopped working.. side light, main beam and indicator works all ok and the n/s works perfectly as well.
I have swapped bulbs and ballast packs side to side and alternately (os bulb+n/s ballast pack, n/s bulb+o/s ballast pack etc) and all the components work fine in the n/s unit.
I have checked the fuses which were fine..
What other components make up the system? What else should I be checking? What else can I change?
I'd guess check there is a current but my electrical knowledge is limited- i'm not sure which wire constitutes the power, I also now figure its a bumper off headlight out job which I wanted to avoid.
Any help would be brilliant as headlights can be useful!! (And I don't want to resort to buying new parts which I don't necessarily need!)
​Oli
