One of my wheel bolts...
Car  Cli0
So have come to notice that One of my wheel bolts does not tighten up, The other 3 on the wheel are fine. Ive tried a couple different bolts in the same hole but still nothing. Should i just buy a new rear hub from eurocarparts or something? HELP :neutral:
I cant really tell tbh, there is thread there, but it may have worn down just enough to not get a grip. I don't know.
I'd drive the car home, a short distance on three bolts.
I wouldn't recommend to others to do it in the long term.
As above get a Helicoil/recoil thread insert.
Just as strong if not stronger than the original thread.
Running 3 bolts is dangerous, Renault fitted 4 bolts in the first place for a reason. Even if you get the bolt in there and manage to tighten it to a fashion there is a chance it will come out and make a mess of your car on its way.
