No good fella , do i need to phone o2 ?
Not had an iPhone before, just seeing if i get on with it today, do i need to activate something ?
.sorted
Weird one here but does anyboday's battery die like in hours,
It was fully charged this morning @ 4 when i left the house, and by 11.30 it was down to 2%,
i only used it for 40mins to listen to chris moyles podcast, surely this wouldnt die the phone, Wi-fi is off, so cant be that :S , is there a way to do Task Manager? to see whats running in the background?
Done some research (googled it) and apparently Apple use a chipped lead so it will only work with their, massively overpriced, cable.
What a f**kin liberty!
Have you got a link to this cable?
The LAN IP address is simply the IP address of your computer on your internal network.
Open a command prompt and type ipconfig on your computer. It'll give you the IP.
Make sure it's UDP port 7 you forward as well. Although WOL should work over any transport or network layer protocol, it's normally sent as a UDP datagram these days.
Ok thanks....Is it the default gateway IP or the IPv4 Address?
Edit:Its the mac address for the Ethernet adapter isn't it?
It's the IPv4 address. The default gateway is the default route the computer takes to get to networks not otherwise specified in the routing table.
And yes, it's the MAC address for your computer's ethernet adapter. Type ipconfig /all into a command prompt to find it.
Has anyone ordered a pay monthly 3GS from 02 online recently?
Just wondered how long delivery was
can you cancel a text when you press to send it?
if so... how?
