Open door symbol on dash lighting up.
Car  Renault Clio 172 Cup
When i lock the car there is a constant beep noise, so i unlocked it then i seen the open door symbol is lit up on the dashboard i opened the two doors and it stayed on but when i opened the boor and closed it, it flickerd off then it came back on again. Any ideas what the problem could be, cheers Will.
the constant beep is purely because its showing something is still open
u will need to go through the switch's to determine which 1 it is,for the cars i have done its usually the bonnet 1 but every car is different.
the boot 1 need the t20 torx taking out and the cover pulling off to get to
Cool, ill have a check on the switch's tomorrow pretty sure its the boot one tho tbh, annoying as i had a new boot catch fitted 2 months ago, cheers for the quick reply mate.
