S sideways danny Car ITB'd MK1 Mar 9, 2010 #3 data have a look on catcams website. Near as dammit the same as a 420
S sideways danny Car ITB'd MK1 Mar 9, 2010 #7 clearance [cl] 0.00mm 0.00mm duration [0.1mm+cl] 269° 256° duration [1.0mm+cl] 231° 219° valve lift [cl=0] 11.25mm 10.25mm cam lift 5.70mm 5.20mm peak angle 124° 104° timing [1.0mm+cl] -9/60° 33/ 6° lift at TDC [cl=0] 0.40mm 1.55mm
joker83 Car Clio RS 172 Mar 9, 2010 #8 sideways danny said: clearance [cl] 0.00mm 0.00mm duration [0.1mm+cl] 269° 256° duration [1.0mm+cl] 231° 219° valve lift [cl=0] 11.25mm 10.25mm cam lift 5.70mm 5.20mm peak angle 124° 104° timing [1.0mm+cl] -9/60° 33/ 6° lift at TDC [cl=0] 0.40mm 1.55mm Click to expand... this is the 420 catcams...the original are the same?
