Glad to see the sun was out for you!
Yes but not for ages and only in RWD cars.Have you ever been in the dry?
Having 7850rpm on tap meant we were only chaging gear down to 2nd for the bus stop and then doing the whole of the rest of the track in 3rd!Track looks pretty fun for a clio, car seems to pull along nicely in the rain with out much bother too!
Think most people were needing 4th gear on the longer straights due to the usual F4R tail off at high RPM that the standard engines suffer with.
On the 197 cams also?
My car used to go 7650rpm. made it much more drivable with those few extra revs.
Was advised that going above that could give valve knocking? presume yours doesnt get this. (ive probably got that term completely wrong)
Would've gone quicker if you had a pair of oars haha.
Nice to watch another of your videos with some lift off oversteer
What sort of tyres were you using? Although I dont think anything would've saved you on that sort of surface and those conditions loll
Looks like you and Lesley were going well
I think the term 'struggling for grip' was quite suitable there!
Really want to do trackdays now, but lack money and power!
We were on nearly new federal RSR 595 tyres, I felt they worked really well TBH, was very happy with them given the conditions, although we need a bit more camber on the car (but it doesnt get it as its my mrs daily driver) really as it did work the outside edge of the front passenger side tyre.
I think they are the best all round tyre I have ever used, they are excellent in the dry as well, not quite 888 good, but not a very long way off it.
Nice bit of my car at the start of that, pretty sure I stuck with you after i let you through as well.
Seems to have gripped well for those tyres in the wet mate.
Could the outside edge not have anything to do with the ammount of tow out you're running? If you're running any ofcourse
I only let you past as it was an in lap....... does make me want a few more ponies from my engine.
T'was good fun, wish I could have stayed longer
I had a ball in the car with least power on the day. Thanks for the ride Chip couldn't believe you not having to change gear on the straights. The car handled well.
You had a lot of in laps
Andy, i found myself having to lift occasionally on the straights when i was following you, not sure if it was a better corner exit or if you are down on power though, might be worth getting it on a dyno to get the power checked out.
I was losing alot of grip through my front left, need to do a trye swap front left for rear right (as it looks new) I'm also looking to get some camber bolts and shims to see if that helps in the corners but at the end of the day its a 129000 mile 172 so it probably needs a good tune up. Cambelt is due soon and looking to get a few bits sorted
Ours that we were passing you in is 143,000 miles
(i admit we may have refreshed "a few" bits though, flol)
Standard engine chip?????
I think not.
