Outer CV boot
Car  Octavia vRS tfsi
Changing the springs and dampers today and I see that the outer cv boot on the driver side is after spitting out some grease over the last few days. Can anyone advise of the correct part number for a replacement?
Renault Ireland are woeful with the provision of any sort of correct parts.
Appreciated,
Ian
best to get one from a motor factors. If you do go for a rubber cv boot as apposed to a thermoplastic one (which i think renault would supply) the rubber boots can be stretched over the cv joint to make fitting easier, the thermoplastic ones requive the cv joint to be taken out the driveshaft to fit, major ball ache
