Overheating problem - fan issue
Car  MK1 Clio Versailles
Well my car passed the MOT today which I was chuffed with, so now onto the next repair job.
The fan doesn't cut in say when stuck in traffic and I had one nasty overheating incident when in a long jam. Whereever I travel now, if I'm stuck for 15 minutes or more in slow traffic, I get close to overheating.
Problem is I have no temperatue guauge (it's the shitty low model) and only the light comes on warning you that you should turn the engine off etc.
Now we had a look and the fan was slighty stiff (evidently hadn't been working for a while when I had it).
I've loosened it up, and let the car run for around 15/20 minutes and didn't get it to overheat let alone the fan run.
Any ideas what the problem could be? Would I need a new fan or could it be the leads?
I would think your fan motor has seized if it was stiff at first. Go to the local scrap yard and take one from another Clio and try it.
do what i have done in mine.... bypass the switch and have a switch tucked away somewere and turn the fan on and off when you want it to... works a treat
james
james
Some Clios actually have this as standard (although its not intentional!!). On some mk2ph1s if you hold both the elec window buttons in the up position (with the windows already up and the engine already warm) it causes the temp gauge to rise :S , tricking the fan into coming on.
