Wont have pics available for a while. Havent got a digital camera, and havent worked out how to send it on my phone yet! I need to do the rest first before i show anyone!
Plan on painting every part of the door card black, except the storage bit at the bottom. Thatll be done in red to match the car, along with the insert being done in a red leather to match. Then ill have my richbrook flashy door pins in red!!! Should look subtle but good! Subtle is my thing - dont like OTT.
I would say definitely do it though, i can already tell its gonna make such a difference. Id use that folia tec stuff too.
Basically i cleaned all the crap off it first, then wiped it all down with thinners to get rid of any silicone and excess crap.
Gave it a good coat of the folia tec plastic primer.
Left it for 10 minutes to go tacky, then gave a light covering coat of black folia tec spray. Dont try to put too much on or itll run & give a rubbish finish.
Gave it 3 coats in total waiting 10 minutes between each.
Left to dry for 1/2 hour then gave 3 coats of folia tec sealer spray, again leaving 10 minutes between coats.
Did all that just to make sure. It really was worth it though as the end result is brilliant. I can scrape my nails over the surface and nothing comes off!
Ill get some pics up when the cars done (about a month), coz all the interior should be sorted except the re-trim.
Hope this helps,
Al
