Painting My Wheels?
  MK3 GTI golf 16v
i personally wouldnt paint wheels with hammerite. get them powdercoated, its not expensive and will look a hell of a lot better
  MK3 GTI golf 16v
my mate had his motorbike wheels done for £40 for the pair. so id hazard a guess at about £80. they will look like brand new wheels though, its a good finish, id go gun metal on them alloys, looks proper nice
LiamR172
Scotland - NW
i live in the north of scotland so it would probs cost a bit for P&P, any ideas on a place up this way?
or should i just search the net?
Just use google and search for alloy wheel refurbishment or powdercoating around your area.
The cheapest i found in the NW was £140 car in tyres stripped, filled, powercoated, fitted then balanced.
  BMW E36 328i Sport
quite easy to do them yourself mate I did the wheels on my last car.
Sand them back
fill any scratches with chemical metal
sand that back
spray a good few layers of primer
then a good few layers of your colour
and lots of layers of lacquer
I didn't use hammerite just normal rattle cans
LiamR172
Scotland - NW
Sand them back
sand that back
thanks, im not the best at painting and decorating so i dont know about paints :p
could you tell me a decent make of primer and lacquer?
sorry for being thick xD
LiamR172
Scotland - NW
Also can i just say... im not looking for an awesome finish because when i get back to work in a few weeks im going to save a bit and start changing the car, so a new set of wheels will be ordered. i just want to play about with these ones just now :)
Knuckles
ClioSport Admin
Halfrauds primer, spray and lacquer ftw... That's what I'm planning on using if I decide to White my wheels, there's a couple of guides on here, should be interesting to see how it turns out lol
I did a decent job of my 172 wheels, when painting with rattle cans the key to a good finish is all prep work...
As with most painting is prep imo...
wet flat the primer, dust primer, 2 or 3 coats of colour... dry... good even coats of laquer... done...
Mine took 2 evenings because they where curbed... id say about 6 hours work but i took my time
After you've sprayed on the primer and let it dry, you can use fine sandpaper... i.e. grit 2500, 2000 (can be got anywhere... online... etc) with water and lightly smooth the primer to a very flat surface... (wet flatting)
This means your paint will layer on top smooth and give a good finish... Then dust primer is just a quick spray over (im not sure if necessary) after wet flatting, before colour.
Have a look at some guides and you will understand it more
Christopher
  Z4M
Where was that?
