Part number Help please!
I need to know the part number of the bolt/bit of stud that holds the cover over the fuel rail. The fuel rail cover is usually held on by two bolts/studs, one of mine has sheared and needs to be replaced. The cover rattles at certain revs which is annoying.
Any peeps with Renault part numbers on CD/catalogue, I really need your help!!
Thanks in advance,
Dan
Sorry to sound dim but.
The cover locates onto the two studs that wind into the engine block and then the nuts hold it in place. I need the stud part number and nut.
Is the part Im talking of called a nut but is in fact two pieces??
Again, sorry to be so thick. Its just Im trying to get this part tomorrow and wont have much time to visit Renault.
Is it likely to be a stock item?
Yes, the stud screws into the head and the bolt holds the resonator onto the stud.
77 00 108 001 BOLT M/FOLD LA 1.76 ---3 x 1
Thats the bolt/stud you want.
