Pas bleed + intial start up
Just checking it only needs for fluid to be topped up and turned lock to lock a bunch of times? I just filled the system, it took 0.5L, turned it lock to lock and fluid basically hasnt gone down, It took the fluid very quick. Its too late to start it now but will it be fine? Should I start it and turn it lock to lock again?
@bloke Belt wasnt off. I have just turned it on, whined a bit, turned the wheel, topped up a few times, about a litre in now, went pink throthy. I kept the cap off to see and now it seems to have settled. How do I know if its done its thing, does the throth settle down? Shall I leave the cap off for a while with car off? Cheers!
No throth now, wheels a bit firmer than before but it should be with the new rack. No whines. Just gotta test it now! Been a massive mission doing this and new custom lines as well
micro bubbles should sort themselves out with a little bit of use but rare they need topping up after the first time.
Yeah alls well. Just went for a drive and nothing broke, nearly bald p zeros on the front not the one though, quick rack + greasy roads = :S
