Which PAS line you talking about? If it is the high pressure line from the Pump to the rack then I can only think of one mount which screws onto the plastic fan shroud under the fuel rail guard and supports the flexible part of the line. The other mounts are permanent mounts brazed to the rigid pipe. They are bolted to the front of the gearbox, the end of the gearbox, the heatshield by the Exhaust manifold and lastly on the Steering rack.
