pas pump?
Car  ly 182
I have a whining once steering underload but when steering during stationery there doesn't seem to be any problem , I know this question as been asked a few times but couldn't find anything roughly the same and don't want spend the money on having a pas pump if ir could be something else as its not a cheap job to have done and might not even be the problem
They're at the age now... not bloody cheap either for new from Renault!
Just FYI though - 2.0 16v (F4R) Scenic I, phase II PAS Pumps are the same which will help some stupid Autofactors find a pump for cheaper ;)
Recons aren't but brand new are pricey and you need to press the tri-point spindle to which has to be at the precise dimension to stop it destroying the aux belt.
EDIT:
NEW - £293.65
RECON - £167.58
My mate said from the symptoms were like the ones he had when the pipe had gone , is there a easy way to check the fluid level or do u have to take all the skuttle panel etc off
