what's the point in the two PCI-E slots then? With my budget, based on that system, I've got £181.98 left for improvements.
The motherboard isn't SLI compatible AFAIK. I don't think Intel have an SLI-capable chipset as yet? Tbh, if you can push your budget a little more look for an nForce680 based board, I prefer them!
i think this is the same board (cheaper) :
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=491417
but the memory speeds are 1200 / 800 / 667 / 533 not 1066?
I think I may just go with the single gfx card then, but upgrade to a mobo that can support 1066 memory and get 2gb in 1066 instead.
Reading TomsHardware, did some tests on an two SLI card v one card at the same price of the two SLI cards. Tests came up that the SLI was a better for some and worse on others. Hit and miss i suppose.
Personally I think SLI and Crossfire are a complete waste of money, by the time they become common place with worthwhile performance benefits the game will have moved onto the next gimmick. Theres no software out there that will push a good rig to unplayable quality.
You sure can - they've even had nForce 4 mobos in Intel & SLi combo for quite sometime. More often than not, nVidia make both an AMD and Intel spec of the same chipset - such as the 590 and the 570. Clearly, the 680i is an Intel-only option at the moment though.
Just make sure (because I'm lazy and can't arsed to check!) that the Gigabyte mobo offers true x16 on both PCI-E interfaces - effectively giving you x32 in SLi combo. Some of the older gen SLi mobos only offered one x16 and one x8 PCI-E slot.
As for your SLi question, you never get true double-performance with two cards in. A good 60-75% increase can be achieved normally - perhaps more when the game is optimised for it (like Call of Duty 2).
D.
you may need to refresh the screen as I've re-used some of the image names on photobucket, the motherboard is now the EVGA one and the memory is 1066.
Its probably not worth going for the EVGA board thinking about it now though, if I'm not going to do SLI, then I may as well get a different board that supports 1066MHz memory, they seem thin on the ground though, the only other one I can find is an Abit, but its costs almost £220.
ok chaps, thanks for the advice. I'm currently looking at (for the base system):
which comes out at £722.03
with:
at £1013.29
or with:
at £1093.19
or with:
at £1121.52
so it depends on money at the end of the month.
ok, I've checked the dimensions and the 620W Corsair will fit, so I'll take that.
D.
If you read my post I'm talking about Intel chipsets, which is listed on the motherboard he's chosen at the moment (a 965, to be specific). The chipsets you mention are all nVidia.
If you're going to correct, at least be correct:rasp:
I have 2 of these...
http://www.overclockers.co.uk/showproduct.php?prodid=GX-035-BG&groupid=701&catid=56&subcat=877
It's a beast, I assume you wanna play pc games with it?, it runs every single game I have perfectly with all the graphics turned up like Rainbow 6, Battlefield 2142 and all the other new ones.
It'll all be out of date in 6 months...
