Ph1 172 central locking issue ??
  Clio 172 ph1
Hey there so my issue is I can only lock my car by using the button inside the car to lock it , I've changed the remote battery and still no joy if I lock the door using the key it will only lock the drivers door no other doors lock , where can I start to look ?
  Clio 172mk2
mates started doing this other week (1.2) but could be same. just disconnect battery for 5 mins, then it started to work as normal
  Clio 172 RS ph1
bump,
Mine has done it too out of the blue for no reason whatsoever.
the spare key works fine.
any1 has a solution?
*key blinks twice if you press the button for a second, tried replacing battery, no joy =(
