Ph1 172 Fuel Pump
E11OOT
  182/V6/R27/R26R
Need to source a fuel pump as I think mine has given up the ghost.
Fuel pump relay is good but cant hear it priming when the ignition is switched on. Pump wiring is getting 12V also.
Any one know the Renault part number or an alternative that is a direct replacement into the housing?
  dan's cast offs.
doesn't prime on first ignition, second onwards. pop the fuel line and check it's priming.
E11OOT
  182/V6/R27/R26R
The engine will crank but not fire.
The pump is 100% not 'whurring' on second ignition.
I have a second 172 sitting in the garage and tested them back to back and in one you can hear the pump prime and the other you can't.
E11OOT
  182/V6/R27/R26R
For anyone else that is wanting a replacement pump, I installed this one yesterday. Solved my starting issue.
It is a touch longer than the standard unit but it did fit ok.
  • Item Name: Fuel Pump
  • Part Brand: ESEN SKV
  • OEM Numbers: 133356 / 250602674R* / 250607248R / 393750135 / 5968084 / 5982573 / 7153374 / 71737182 / 71753374 / 71753374* / 7580214 / 75802140 / 7672473 / 7688265 / 7688480 / 7700416988 / 7700416988* / 7700418353* / 7700811046 / 7700811048 / 7700825250 / 7700825251
  • Weight [kg]: 0.36 kg
  • Diameter [mm]: 36 mm
  • Number of Inlets / Outlets: 1/1
  • Operating Pressure [bar]: 3.5 bar
  • feed rate [l/h]: 110 l/h
  • Voltage [V]: 12 V
  • Supplementary Article/Info 2: With filter
  • Length 1 [mm]: 64 mm
  • Length 2 [mm]: 138 mm
  • Diameter 1 [mm]: 22 mm
  • Fitting Position: in fuel tank
  • Operating Mode: Electric
  • Fuel Type: Fuel
