ph1 172 idle problem
  Megane 225
right as the title says i have an idle problem on my 172. when starting the car from cold the engine dies straight away unless i rev it. then after like 5 mins the engine will not idle at the correct revs and rises and falls between 1100-2200. this keeps happening untill the engine is turned off. start it again car idles as normal then as soon as i touch the throttle the engine startsc revving itself between 1100 and 2200 revs again. if anyone has any idea what this could be plkease help!!!!!
oh yeah its had a diagnostic check and no faults wrer found
-KarL-
does it stop if you lift the pedal?
mine does it from time to time as the cable sticks
  clio rs 2000
if the idle is lumpy your iac valve needs a adjustment or changing
if the idle stays constant for example on 2k your throttle needs a little motor oil
but yours seems to be teh iac
take it over clean and turn it a quarter turn clock wise
then put it back
4 cables comes to it finally check the 4 cable which comes to iac
if one of them cut it also makes like that
  Megane 225
no it doesnt stop when i lift the pedal it just seems to do what it wants!! lol recently had a new cable fitted coz my last one snapped
  Megane 225
take it over clean and turn it a quarter turn anticlock wise
then put it back
ok mate il have a look at that 2moz. bit dark now! lol thanx
  clio rs 2000
if you never take the iac off
i must have 2 rivets on it so cut the rivets
and while refitting it apply there 2 screws.;)
after that you can take it when you want
you can adjust and clean it like that
i think the ideal gap must be approx. 1.5 cm
