Cheers James, Yes seen the immobiliser dis-arming thing, but I'd prefer to keep the immobiliser working. Do you know whether I get the existing key re-programmed or is it a case of new keys?
Get the key recoded mate, or there's a little device you can but for £100 and pput it in the odb port under the ash tray and it deletes the immobiliser
There's an ODBII dongle product floating around that is vin coded and simply inputs the bypass code for you. This only works on the older generation vehicles it is probably worth noting and will only work on the vehicle it has the vin programmed in to memory to stop thieves rolling round with them in their pockets.
A new key for a phase 1 supplied and coded is around £165. If you paid £25 it will probably be a non RF plip.
