What type of exhaust? If its aftermarket s/s they normally come with a sliding adjustable collar to adjust the length of the middle.
If its standard possibly it all depends on if the ph1 has 1 or 2 lambda's in the cat as i think the ph 1 with two lamdba sensors is the same size etc as the others.
If its one lambda sensor only its an inch or so shorter
