PH1 Dashboard conversion from PH2
Car  Clio RS
Hi,
I already converted the lower and the upper part from a PH 2 172 and my PH1 and also the PH2 Passenger Airbag.
But to loom the Passanger Airbag ive got a Problem. The Dissconnector didn’t match at the left side which is solved be modifying the Plug a little bit.
But now there is a Airbag fault because of the PH 2 Airbag does have two sockets which the PH1 Loom dosnt have plugs for. There is only one Plug in the Loom because of PH 2 Airbag is a two step Airbag and Ph 1 is only a one step Airbag.
Is there a possibility to adapt this 2 Step Airbag from the PH 2 in my Ph1 or is the only way to use a resistor ore disable the airbag with the Airbag ECU?
