Hello, I have had a search on the forum and looked at various threads but would like someone with the knowledge just to give me a full answer.
As ph1 driveshafts are difficult to obtain decent ones, I have seen a thread where it lists some options, but says the closed length is 734, and I think it was the skf one stating 740 I'm just about done with it 🤦♂️
What are my options on changing shaft length to later models that you can get shafts for easier and what's the best route.
Basically what do i need to buy?
182 subframe and wishbones? Then I would increase the caster as well I believe as well as the track with?
Also which variant came with the two piece shaft including a bearing carrier? What's needed to convert to this?
