OK, I've used my track only PH1 at both Aintree an Oulton Park and I'm not to happy with the gearing situation.
Now Aintree has quite a long straight which at the end the best I've seen is 122.
The problem is your in 5th gear for a fraction of a second, almost not worth the change
At Oulton, admittedly in the wet, I only need 3rd and 4th.
Is there a box/diff I could fit that would bring the gearing down to allow the use of 5th, I feel I could loose around 10-15mph off the top end without any major issues?
Everything is standard including tyres size so gearing is as per the factory.
Col
Col
