ph1 shift light
Car  Clios
i have a y reg 172
i understand that the x reg 172's came with shift lights.
If i fit the ecu, multitimer and he clocks the shift light doesnt work. Does anyone know if there is an extra wire that needs run on should it just be plug and play.
any advice i would be grateful of
i have a y-reg with a shift light! my mates old x-reg didnt!
i dont think its reg specific, i think it was an addition extra when first ordered!
im not sure what its part of, does your current clock actually have the light that just never illuminates?!
I think it's pot luck if you have either the shift light or Ali bonnet. I was lucky enough to have both on my ph1 ;)
when i took the clocks apart i checked inside both sets. both sets of clocks has the same amount of SMD's in the same places. im just assuming that i need to run a wire to the multi plug to make the shift light, light up.
anyone else tried to fit a shift light?
