ForceIndia
								Gentlemans spec 200
				No responsibility for your engine blowing up or you crashing into a school.
My throttle body spring seems to have broken, so idling at 2k etc, similar issue to a few other people. Rigged this up today, basically using a couple of springs to close the throttle body the final 1-2mm.
Attached the spring to the throttle body using cable tie.
Seems to have done the trick, idle is now back to normal, so should do short term.
