Ph2 airbox - where does the bottom feed go?
  172
Just noticed this when I had the panel filter out, where does it go and why are there 2?
Bought a 70mm feed for the side exit but is it worth re routing the bottom one too?
  BMW M135i
One from the battery side goes to the acoustic valve in the wheel arch, the one that feeds into the back at the bottom goes to behind the headlight.
  Megane 2 GT 165
As Bmh.01 said. The bottom exit, is routed to the headlight. You can see it just behind the headlight. (it's fitted in the metal part between the battery and the airbox.
So is it worth re-routing the bottom feed??? I don't know, it seems fine. BTW I replaced my side exit feed, just for induction sound so maybe re-routing the bottom feed will also give some extra sound.
  172
ahh right cool, i'll leave the bottom one then, i'll just route the side one.. got to say though i've never noticed a feed by the headlight!
  Megane 2 GT 165
Lol I didn't see it till I changed my air feed either.
Anyway when you stand on the side of you car (passenger side in UK). And look at the airbox. Where the side feed is...and look a bit to the left. just behing the headlight. You should see the bottom feed.
