Ph2 sport not starting midday on a track day???
  Ph2 Clio sport
Just wondering if anyone can shed some light on this problem. I did a track day on Monday and half way through the day the starter motor would not work. I was able to bump start the car for the rest of the day (with the help of the lafs) and there where no other running issues. I noticed the starter is right next to the exhaust manifold could it have possibly got so hot and cooked the starter motor??? Im hoping its just a case of changing the starter!Has anyone else had this problem, if so could you help me out.
many thanks
  182/RS2/ Turbo/Mk1
Easy for the solenoid to overheat due to where its sat, sometimes when cooled down again they work for a while but normally once its happened once it ends up failing totally not long after.
  Ph2 Clio sport
Cheers guys, I've since tried it again and nothing, not even a click! Does anyone have a link to how to change the starter as it looks like a tedious job. Cheers
  Disco 3 &4 1993 mini
This used to happen to my cup racer after a 15 lap run it wouldnt start, I fitted a heat shield to the starter and it solved the problem
