Phase 1 throttle cable plastic clip snapped....
  Ph1 track car, Dci
Bought a new cable, the plastic clip that holds the cable and connects it to the pedal snapped when i was putting it on! Can you buy this crappy little clip? As i dont want to buy a whole new cable due to failure of a 2p plastic clip!
  Ph1 track car, Dci
Anyone got any ideas? Im pretty gutted as i cant use the car due to this stupid plastic clip :banghead:
  Ph1 track car, Dci
Where has it snapped? If it's the little barb that secures it in the pedal then you can use a piece of vacuum hose on it :)
Thanks for the reply, Its the plastic fork bit that holds the head of the cable in it, then you use that to attach to the throttle pedal, if that makes sense. Its totally snapped so cant use it.
