realnumber 1
Are the iris not quite large? I’ve got 2x bloom behind my TV and they fit ok.
I use 2 blooms under/behind my tv. They work much better than my iris's would.
Unless the accessories specifically support HomeKit, you won’t be able to control via HomeKit or Siri without using homebridgeAdded some of these smart plugs from Lidl to my hue set up. They work pretty well and connected quick and easy. Also for £8 they are a bit of a bargain. I’m going to look at the rest of their range to see what they have to offer.
The only issue I have is that they don’t work with Apple HomeKit through hue, I assume you need to use the standalone Lidl bridge for that. Although there is a workaround with homebridge and raspberry pi but I know bugger all about them and coding.
Get a starter kit of choice, and then just add individual bulbs from there. Or if you get extra starter kits cheap enough, sell the bridge on eBay to get a bit backWife has approved me getting involved with smart lighting.
So just need a Hue Bridge and build from there?
They're white only bulbs, so are cheaper than the full colour ones
