I can't split the bead, there are 5 steel rings around each bead which I can't get to, any ideas.cut it in 1/4's and it would work
My point entirely. His argument was that the rubber will clog the disc, cause it to spit in an offset fashion and shatter! I've heard of it happening when a disc is fractured but not through cutting rubber.Why would it be destroyed by cutting something which is comparitively soft?
Any tips?Your not trying hard enough! stinks a bit though!!!
the grinding discs r designed for a purpose.
if you use a metal disc to cut wood or plastic it clogs all the holes up in the disc resulting in air burst or something where the disc shatters and youd prolly have a few bits of disc stuckin your face.
now go for a drive and it will come off no bother
