Play in 172 throttle housing
Anyone know of a cure ?
Mine is over revving, first was idle valve, that is now sorted (hint, get one from eurocarparts, you have to drill out the rivets and fine 2 small nuts and bolts but it's 25 quid with the vat and a genuine VDO as fitted)
Then the throttle is sticking, cleaned out and is better but the is a wiggle of play, just a small amount but causing it to stick due to cable pulling force
Anyone found a solution for it ? I'm thinking new throttle housing but if anyone has rebuilt one I'm willing to listen
