PMS Linkage Rattle
Car  N/A
All,
I have the PMS shifter fitted, however suffered with the linkage rattle at a certain rev range.
Fitted the cheap linkage fix KTEC offer but still a rattle top end?
Is this normal or an underlying issue with the linkage itself?
It doesnt work at all, i had the garage fit it in various places with no success so upgraded my speakers to drown out that noise when it sits about 3k rpm on the motorway. Great shifter to have over standard though
Strange for mine, I have a rattle on hard acceleration, rather than slowing which most appear to suffer.
@bloke has some thoughts, but its a little more annoying and apparent than most endure on here.
I had the rattle on hard acceleration on mine initially in 2nd gear, was highly annoying. The selector rod was catching the subframe slightly with engine movement, so get underneath, slip it in the gear thats causing issue and check clearances. Adjusted it and fitted vibratechnics mounts, job done.
Same as mine. Get it up in the air and check the rod is not catching anywhere and has plenty of clearance when in gear.
