PMS Shifter
Car  Clio 172 & BMW 335D
Anyone have any hints and tips on how to fit?
Seems easy from the fitting guide however I'm sure there will be a few snags along the way.
PMS says put it in reverse to line it up, does this work better?
Thanks Josh
Fitting is quite straight forward, its the lining up the gears which is the biggest headache, I initially lined mine up in reverse, but had a few problems with selecting fifth and reverse. Then I used fourth gear, which worked perfectly, not had any problems since! :)
Put the gearbox in reverse and then put the gear lever into the reverse position (obviously). When the gear lever is in the reverse position, zip tie it over to the left and make it as tight as possible. You'll then have no selection issues when everything is tightened up. That's how I did mine, and it was bang on first time. :up:
Did you use a ramp to fit or is it possible on my back in the driveway ahha
Very easy to do and as above: mock fit the rod to the box, put the box in to reverse, then the selector in reverse, tighten the linkage and go enjoy.
Went to try mine last year and the exhaust heat shield nuts were just spinning! Need the motivation to go back lol
