PMS stud conversion!
Car  Ph1 172 (titanium)
I have 25mm hubcentric (bth) spacers upfront, and the same (bth) but 15mm at the rear, both sets from dan@mad on here.
Was thinking about going for stud conversion, will the pms stud kit go straight on with no problems, or would I require different length studs / modified studs etc?
25mm spacers will be to wide for the PMS' stud kit. It does say up to 12mm spacers on their site but you can get away with 15mm as that's what I've currently got fitted to mine.
You can bolt the PMS kit into the 25mm spacers though with no issues, The PMS recommendations are for spacers that would be fitted over the PMS kit (Not bolt to hub type spacers)
So what your saying is, their studs would be too long/or aren't suitable for fitment into the spacer, instead of the hub
PMS studs are fine for fitment into the spacer on the 25mm's 100%, I'm not sure on the 15mm's as iv'e not tried them but I'm sure iv'e heard of a few people fitting the PMS kit with 15mm spacers.
Thanks dan, I will dig a little deeper. Or perhaps someone else who has done it will step in with some options!
No reason why it won't work, you have been bolting your wheels to these spacers with bolts right :S
Whats the difference with the studs?!?!? They have 10-12mm shank much like how a standard bolt would penetrate into any Clio hub or spacer.
