Poly bushed the front end Now wheel wobble, help?
Car  Silver Clio 172 Phase 1
Hey guys as the title says really just poly got the front end of my clio 172 ph1 poly bushed, Wishbones and inner/outer front ARB. However after changing these over i have noticed a slight vibration through the steering wheel, No vibes before and wheels are done up correctly and fully balanced? Any ideas? Tracking perhaps or something else?
Any help much appreciated.
i guess fitting new bushes has changed the geometry slightly from worn bushes, but i wouldn't expect a vibration
Yeah the sleeves are tack welded in place, checked them earlier and the welds are still fine. Its not a mad wobble but i can feel a vibration through the steering wheel its all through the speed range 30+ and eases off / gets worse with no particular routine to it. Sometimes i can hardly notice it and sometimes its much worse : (
prob worth checking the bolts are all done up, though i guess if you've checked the welds you've done this. maybe worth getting the wheels balanced? just guessing now though
Yeah everythings done up ok, and i know the wheels are fine as had them balanced a few weeks ago and all the weights are there :(
