Pops and bangs map rstunner or elsewhere
Car  197was/second 182is
Hi! Im thinking about getting pops and bangs map to my 182, what is best place to get one? Rs tunner will be cheapest, but is it good? If not who you recommend in south east? Thanks
RSTuner will be fine mate. It's also good as a diagnostics tool or you could always sell the unit on after in the parts for sale section, people snap them up on here.
If it will kill my car it will be time for turbocharger :smiley: thanks for replying!
You'll be essentially over fuelling mate. And the noise will probably end up irritating you, your neighbours and everyone you drive past. Of course, it's your own decision and if it's something you enjoy then go for it but in my opinion get the RSTuner and bang the 98RON map on instead. Performance > Noise.
The pop n bang map is the same as the 98 ron map apart from on over run after 4k revs i think it was it retards the ingition timing right back to create the bangs
I think I've got 98ron map now... And when its cold it does pops quite loud... I think I will like it, specially if it's only over 4k rpm as it is kind of choice use it or not
Does this damage the engine in anyway?
It depends on how much you use it tbh. Turbo cars with launch control works in the same way retards ingition to hold revs creates the bangs but only should be used for a short time (3 seconds).
Ignition retarding creates alot of heat in the exhaust system and can also help with dropping valves due to heat created
So letting revs come down from 7k listioning to the bangs isnt ideal and will damage the engine its a risk end of the day
Right if I buy second hand I need license for 60 euro and map for 49. If I buy new one which is 199, I don't need license, but do I need map as well? Or is it included?
Im unsure how henk does them these days
It was buy a used rs tuner say £100
Buy the unlock £???
Buy the map £???
Then its locked to your car
Sell rstuner £100
So basically I work out it's cheaper to get new one and then sell it for 100 pounds... Not too sure about shipping cost yet. Thanks!
So is it cheaper to buy new if intending on keeping the module?
I just had a look on the website and it says +€29 for the airbag module,will this turn off my airbag/serv light as I don't wish to use resistors.
Yes it will its a very very good add on
I bought the pop and bang because i needed the rs tuner. Now i cant buy pop and bang file/map. Beacuse they wrote that is incompatible. I get my money back (49 euro). I am waiting for your have! Thanks
Yeah it comes pre mapped.
Where you based? I'd highly recommend efi in Runcorn tbh. Over the tuner too
Get it mapped there mate. I've had Rs tuners before and don't get me wrong it's fine. But for 160 in efi' case I'd allways go there with a clio. Before and after map and done to what you have on the car etc
