Clio MK 4
Mine are squeaking badly and need replacing so thought might aswell spend a bit more and upgrade them. I'm not very clued up on them so wondered if this sounds ok? I've searched on here and think this is quite a good set up?
Brake Pads - DS2500's
Brake Discs - Brembo High Carbon's
Brake Lines - Goodridge Braided Brake Lines or KTR BRAIDED BRAKE LINES C/W STAINLESS FIXINGS
Brake Fluid - DOT 5.1
Should i change the calipers or will this not matter so much. All this for fronts only as i believe standard rear brakes are ok?
Now the question is where to get it all? been looking at yozzasport and ktec. Are there cheaper places?
I
I
